Should be "WinSCP.com" instead of "WinSCP.exe" in the hint for script/batch
Horus
In menu "Session" > "Generate session URL/code" > "Script" tab:
* For format "Script file", at the bottom we have the hint:
# "C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\writable\path\to\log\WinSCP.log"
But I suppose it should be WinSCP.com
* For format "Command-line":
There is a hint behind the drop-down menu and there, it's also written WinSCP.exe but I also think it should be WinSCP.com
Have a nice day :)
Re: Should be "WinSCP.com" instead of "WinSCP.exe" in the hint for script/batch
Well, that depends on a context.
If you run this from a batch file, you will typically use winscp.com (as the "batch file" template shows).
But in other contexts, you will typically use the winscp.exe.
Horus
By curiosity, what other contexts do we have?
I remember I've also tried to type the whole command in DOS window but got error. That's why I thought we should always use .com instead of .exe.
For example any kind tool for task scheduling or automation, like Windows Scheduler or SSIS.
Horus
OK, I see. Normally I would “encapsulate” the commands inside a batch file before calling it in task scheduler so that’s why I don’t use it directly there.
OTOH, I have just tried the same command (or maybe a bit different) with .exe and I didn’t get any error!? That’s weird. I can’t really remember what version I was using when I tested .exe vs .com. Maybe something has been changed between versions.
Anyway, this thread can be closed.
