Using WinSCP3.com Can't Set The Timeout more than the default value
Vazan
Hi, I work for a company this use WinSCP3.com for automatic transfer.
We are trying to set the timeout to more than the default value. We try on the Advanced setting , it's not work. We try to add /timeout to our bat file. It's does'nt work too.
I've search for so many hour about this without find anything for make it.
Re: Using WinSCP3.com Can't Set The Timeout more than the default value
You are using an obsolete version of WinSCP. Please upgrade.
