Creation and moving of files takes place at same time???
zenpie
USA
Hi, I've got a curious question. What happens if the moving(remote to local servers) of the files takes place while when they were being created at that particular point of time(like 08:00, 09:00 and so on).
Will all those files be moved without fail. Or else some be missing.Or something else happens. Plz tell what happens?? :mrgreen:
Re: Creation and moving of files takes place at same time???
Sorry, but that's a too broad question. What files are being created? Local or remote? What is the remote system? What protocol?
zenpie
Hi Martin, The xml files are being created in a folder of remote server. That remote server is a Linux server. And the protocol being used for that server is SFTP.
The thing is that, what happens if the files being created and also they being moved to a folder in local machine at the same time?
zenpie
USA
# Establish the connection
open sftp://(remote server details along with private key)
option batch abort
# Force binary mode transfer
option transfer binary
get -delete -preservetime -resumesupport=off "/users/client/xml/*.xml" "E:\ImportedFiles\pdf\*.*"
I'm using wildcard for selecting the files.The above is the script. Thanks!
WinSCP will retrieve list of all *.xml files in the directory.
It will then download and delete those.
If new files are created during the operation, WinSCP will not process those (as it is not aware of them).
