where are the key files of winSCP located!?
openSuseman
how to find out the location where the key files are located
background: i have ported over WinSCP from one computer to another...
i ve installed the winscp newest version on the new notebook -
according to this manual https://winscp.net/eng/docs/config#transfer
and ported over the ini-data as adviced...
but all i get is an error...
loginprotocoll:_see sessionprotocol for Details):
Unable to use key file "E:\_data__export\filezilla_\filezilla_pass_file" (unable to open file)
Verwende Benutzername "vhost".
well - i have to copy the key files too.
but where are they located!?
openSuseman
by the way - does a stored session may help here?
in other words: i store a session of the winSCP on the one notebook - and then i copy this file to the second notebook
does this help here!?
Re: where are the key files of winSCP located!?
The keys should be located in the directory, where you have configured WinSCP to look for them.
I.e. in the E:\_data__export\filezilla_\.
