Get files starting with a specific name
jonathanf
I've searched all over and can find pieces of what I need, but not the whole thing.
I'm using PowerShell to script checking whether a file exists and then download it. Every month, two new files come in that I need to pull. They begin with the same phrase but end based on the month of the year and then have a timestamp before the file extension.
So right now, I have the following file on the server:
Report_rptTotalMilesAndRanks_20160916111841_Final.csv
That one has been processed. I need to get the new file when it comes online, which will have the following portion of the filename stable:
Report_rptTotalMilesAndRanks_201610*Final.csv
Where the * is in the filename would be the date, year, and time the file was generated.
How on earth do I tell WinSCP to look for a file beginning with "Report_rptTotalMilesAndRanks_201610" and ending in "Final.csv" with a wildcard in between?
Re: Get files starting with a specific name
Your syntax is correct: Report_rptTotalMilesAndRanks_201610*Final.csv
So I do not understand, what is your question about.
If you have problem, show us your code and a session log file.
jonathanf
North Carolina
try
    # Load WinSCP .NET assembly
    # Setup session options
        HostName = <redacted>
        UserName = <redacted>
        Password = <redacted>
        SshHostKeyFingerprint = <redacted>
    try
        # Connect
        # Download files
        $transferResult = $session.GetFiles("/Reports/Report_rptTotalMilesAndRanks_201609*.xls", "c:\users\jonathanf\Desktop\download.xls", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
            Write-Host ("Download of {0} succeeded" -f $transfer.FileName)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host ("Error: {0}" -f $_.Exception.Message)
    exit 1
No logs are generated here.
It should be noted here that when I remove the wildcard and specify an actual filename, the script runs perfectly.
You have to enable the logging by setting Session.SessionLogPath.
Though one obvious issue is that you download all files to a single file download.xls, so all downloaded files overwrite each other.
To download the files using their own name, use:
$transferResult = $session.GetFiles("/Reports/Report_rptTotalMilesAndRanks_201609*.xls", "c:\users\jonathanf\Desktop\", $False, $transferOptions)
See https://winscp.net/eng/docs/library_session_getfiles#localpath
