Will WinSCP do this: Auto sync folders on an AWS EC2 server to Win 10 then FTP to shared hosting
Colink
It looks like WinSCP will do what I need, I just want to make sure I have not misunderstood its capabilities.
I have two folders with sub folders on AWS EC2 server that new files are auto added to or updated several times per day.
I want a copy of all new or updated files synced with two matching folders on my Win 10 PC.
I then want to FTP any new or updated files in one of these folders to my website on my Linux shared hosting account.
I want both actions to happen automatically at set intervals.
I see there is a guide for automation and for connecting to EC2.
Is this a straightforward set of operations?
Can most of this be done via the GUI interface, or do I need to do much script writing or enter any command line code (both of which I rarely do, but can follow a tutorial)?
Thanks for reading.
Re: Will WinSCP do this: Auto sync folders on an AWS EC2 server to Win 10 then FTP to shared hosting
This step is easy.
Now it depends, if you really need to re-apply the changes from the previous step (that's not easy, but doable), or if just want to do a new blind synchronization of the Windows 10 folder to the remote Unix machine (that's basically the same task as the first one, hence easy).
In any case, as you need to schedule the task, you have to write a script. WinSCP can generate it for you:
https://winscp.net/eng/docs/ui_generateurl
Just make sure you select "New and updated files only" in transfer settings, before getting the script generated:
https://winscp.net/eng/docs/ui_transfer_custom
For a scheduling part, see:
https://winscp.net/eng/docs/guide_schedule
