Missing 'Modified Date' after copy.
newuser9876
When I copy a file from win7 to windows 2012R2 via sshd (on 2012R2) the 'Modified Date' is missing in the file. This causes that file to NOT SHOW up in the file list, however the file does get copied to the destination dir.
I'm using the latest WinSCP 5.9.2 build 6958. What can be possibly wrong with my configuration? It seems highly unlikely that everyone would have this problem.
THanks
Re: Missing 'Modified Date' after copy.
What does it mean "copy a file ... via sshd"?
What does it mean "the 'Modified Date' is missing in the file"?
Maybe some screenshots would help us understand the problem better.
newuser9876
So the setup up is this:
1) Windows 7 Running WinSCP client.
2) Windows 2012R2 running SSHD (Server).
3) Connecting with WinSCP to 2012R2 with SFTP.
4) Copy of file from Window 7, Copied file on 2012R2 is missing Modified Date, see pic attached.
5) Copy of file from 2012R2 to Windows 7, no problem.
Hope this helps to troubleshoot.
Regards
Description: This is how the file looks after it is copied.
chanh
United States
Blank Modified Date since after version 5.5.6
I know this is an old thread but I spent many days on this issue and finally, I am able to narrow down the issue.
Please see attached file that shows the same file with the same INI file but switching between various version between 5.5.6 to 5.13.3 where it shows the Modified Date is blank for all version except for version 5.5.6
What do you think might be the cause of this problem?
Re: Blank Modified Date since after version 5.5.6
Can you post log files showing a directory listing from both WinSCP 5.5.6 and WinSCP 5.13.3?
Re: Dir Listing 5.5.6 vs 5.13.3
Thanks for your response. But I need full log files. Not screenshots of piece of them.
