Multiple files in folders and sub folders to one folder
slade2000
Perth
Hi All
I have a script that connects to a FTP host and download all files on the host to a local destination. I do this by using the sync option.
Is there an option to copy all files from all the folders and sub folders to one single folder locally?
Thx
sura_f
Transfer all in to a single folder, then all can be downloaded with a single drag and drop
I created a python script (capture attached) that goes in to all sub folders and moves the files that I need from each in to the parent directory (or any specified directory). Once I have all the files in one folder, I was able to select, drag and drop all of them at once for download.
Re: Transfer all in to a single folder, then all can be downloaded with a single drag and drop
This thread is about scripting.
In GUI, you can achieve this by using Find function to find all files recursively.
https://winscp.net/eng/docs/task_find
Then in the Find window, you can select all the files and use Download to download them to the same directory.
https://winscp.net/eng/docs/ui_find
