need synchronize the directories and files of 2015, but not the entire year, just May and Sept.
leonardo07746
cuba
good afternoon, now I suddenly need to re-write my script and need to add a feature that might synchronize the directories and files from two months within the past year 2015, I'm still reading Newer and updated files only under https://winscp.net/eng/docs/ui_transfer_custom#other but it keeps my head spinning, still don't know whether I'm on a good lead article or not.help,thanks
_________________
leo
Reply with quote E-mail
leonardo07746
cuba
Re: need synchronize the directories and files of 2015, but not the entire year, just May and Sept.
Use a file mask with a time constraint:
synchronize C:\local /remote -filemask="*>=2015-05-01<2015-06-01,*>=2015-09-01<2015-10-01"
See https://winscp.net/eng/docs/file_mask#size_time
Many many thanks, then my script must to say something like this:
winSCP.com /command ^
"option batch abort" ^
"open ftp://ftpmetropolitano:ftpmetro@192.168.x.x/" ^
"synchronize local -filemask="*>=2016-06-01 00:00:00" C:\Sabic\JOURNAL /Journals/TRASVAL/" ^
"/log=C:\LOGS_JOURNALS\logsdelScript_!Y_!M_!D_!T.log" /loglevel=1 "
"close" ^
"quit"
the date've changed because my crazy bosses said they're more interested in the files updated after Jun, is the sintaxis of the script all right?
thanks
_________________
leo
leonardo07746
cuba
"close" ^
"quit"
thanks
nah, not that way, that way it saved the files to C:\program files\Winscp\ instead to the location that I'm indicating to save them c:\sabic\journal\, I changed it by doing some research and this did the magic:
"synchronize local C:\Sabic\JOURNAL /Journals/TRASVAL -filemask=*>"2016-09-20 08:10:00" ^
Voila!! thanks
_________________
leo
The actual problem are the quotes.
This is correct:
"synchronize local C:\Sabic\JOURNAL /Journals/TRASVAL -filemask=""*>2016-09-20 08:10:00""" ^
And then the argument order does not matter. This would still work:
"synchronize local -filemask=""*>2016-09-20 08:10:00"" C:\Sabic\JOURNAL /Journals/TRASVAL" ^
See https://winscp.net/eng/docs/commandline#syntax
In your version, I'm pretty sure that the "08:10:00" part was ignored.
Also, the /log must be at the very end (or before the /command). Otherwise the close and exit commands are never invoked.
So a full correct script is like:
WinSCP.com /command ^
  "synchronize local ""-filemask="*>=2016-06-01 00:00:00"" C:\Sabic\JOURNAL /Journals/TRASVAL/" ^
  "close" ^
  "quit" ^
  /log="C:\LOGS_JOURNALS\logsdelScript_!Y_!M_!D_!T.log" /loglevel=1
