getting directories
taw
getting directories
Hi! Could someone help me please
i have a directory on a FTP server, here are a lot of folders with random names. Each folder contains subfolder with defined name. How can i get (via filter or find dialog maybe) and then download this defined subfolders only?
e.g.
../workDirectory/*randomNameFolder*/*folderINeed*/*files*
I`ve been trying it for 5 days =\
thanks for help
Re: getting directories
Download where? Do you want to maintain the directory structure? Or download them to a common folder?
Anyway, there's hardly an easy way to do this. You should have to write some (PowerShell?) script.
taw
to a common folder
oh, i thought it is easy task... have no experience in scripts =\
