WinSCP 5.9.x unable to logon remote hosts - 5.7.7 works fine
mokaz
Hi there,
For unknown reasons i can't get on remote hosts with latest WinSCP builds.
I've analyzed the traffic with Wire-shark and all seems okay although WinSCP just states "Connecting to host..." forever.
Could you maybe pass me a debug version to see what's going on? as stated the 5.7.7 works, will try now with 5.8.4 RC and after that with a 5.9 release.
Thanks,
Regards,
M.
Re: WinSCP 5.9.x unable to logon remote hosts - 5.7.7 works fine
Please attach a complete session log file using both 5.7.7 and 5.9.2.
Papou008
I found the same problem.
It look to come from non conventional characters in my SSH password like "(", "-" ...
Password with only letters and numbers work fine ... but it's not so secure...
Thanks for your work !
mokaz_anno
Seems possible although I've tested the same builds on a VM with the same OS version as my main host and it worked fine there.
And i'm using priv/pub keys to connect on hosts..
And yes, Thanks Martin !!!
So it cannot be the same problem then. The problem @mokaz has occurs before authentication.
Your problem is more likely due to WinSCP 5.9 correctly using UTF-8 for passwords and your server possibly does not. Older versions of WinSCP did not use UTF-8. While that was incorrect, it may have made WinSCP compatible with your server. Though characters like "(" and "-" are ok. They are ascii. Are you sure you do not have any other more-special characters in the password?
