Winscp Memory Leaks
Sheeraz
Winscp Memory Leaks
I am trying to Upload a 11GB file but get regular memory error.
Few things i observed on task manager that Winscp starts consuming high memory i.e. over 1 GB and then it crashes.
Please find attached the command interface .
Description: Command prompt file.
Re: Winscp Memory Leaks
sheeraz
Log File
Find attached log file. The main problem is that the command desent reload at certain point and have to end task and reload again.
  • loadAttempt.log (104.06 KB, Private file)
Re: Log File
sheeraz16
Pakistan
I have reproduce the scenario please check attachment..
  • Winscp.zip (5.32 KB, Private file)
Description: Zip folder
WinSCP MemoryLeaks
I have faced the similar issues with WinSCP 5.13.1. Did you guys come up with any solution to this? what was the reason for leaks?
Re: WinSCP MemoryLeaks
