Generate url adress
itsonlyme
Generate url adress
First I`d like to say that WinSCP is the most greatest app ever. Thanks for it.
I have only one question.
If I try to generate URL (right click) on file
its generat link with ftp://
I need http://
Is there any way to change it to generate automatically www adress to my file?
Ive created folder and I called it the same like my domain name.
So if I copy path I have this
/mydomain.com/test.html
It would be ok, but I can`t kick off this / at begin :(
Anonymous wrote:
Is there any chance to set hotkeys to File Names> Generate File URL?
What do you use it for that you need it so frequently?
Yes, for my use is primary function.
I`ve generate many links to my works (Im graphic designer).
I need to show it to my clients. I make it a lot and must do it do fast.
For this I`ve make the same host name like my www adress,
so I could generate http links for my projects if It will be a way to add http before my url links,
now I generate this for example:
ftp://mydomain.pl/2016/09/2.jpg
So I need to change ftp to http by hand :(
I dream about automatize this work, but I can`t comile it for myself :(((
Hotkey for this will be also very usable
The link I've posted above shows how to add a custom command that generated the http:// URL.
And custom command can have a keyboard shortcut.
