Bug with synchronize
Editorant
Great project I love winscp :)
- Version 5.9.1 (Build 6885)
- Windows 10 (german)
- SFTP
I start a synchronize from remote to locale and get very often a errorbox with "Cannot open remote file"
I have take a look in it and found that always a wrong message, the file exists every time. Take a look in the screeenshot, you see that the "é" is missmatch. That is for all characters like ä ö ü ß é .......
I make here a big backup. The calculation for comparing was > 15 hours.
I have make a short test synchronization for a single folder with images (second winscp process). There was no problem with é ê and ß in file name. So why in the big one?
(Side request: please make "skip all" button to skip __all files__. I must press "skip all" button hundred times in the synchronization. Thats not helpful.
(I can't register me: "You have exceeded the number of registration attempts for this session. Please try again later." What? That was my first try ^^)
  • after_synchronize.png (14.36 KB, Private file)
Description: After all finished I take a look in the local folder. The file is missing.
  • errorbox.png (7.44 KB, Private file)
Description: Wrong errorbox. That File KazéManga.png exists
Editorant
After now press hundred times "skip all" its finished synchronize the upload-folder with uploads from users. Each user have a own folder. I synchronized the upload-folder again with a second winscp app and he found the missing files and downloaded all successful. No errors found.
He must be a problem with a very large synchronize?
Re: Bug with synchronize
I assume there must be a file with an invalid file name, somewhere in your directory tree. When WinSCP gets any non-UTF-8 text from the server, it assume the server does not use UTF-8 encoding and stops converting the files names. If that decision was wrong (the server uses UTF-8 in general, except for that single text/single invalid file), it effectively breaks any later use of any non-ASCII file.
Editorant wrote:
Is here a setting for fix file names as utf8?
Sorry, but I do not understand, what you mean.
