Can't connect to b10ftps.tgms.gxs.com:6366
mdrex01
OH
Winscp 5.9.1, Windows 2008 server, can't connect to b10ftps.tgms.gxs.com port 6366 data channel port range 40000 - 49999 using FTP TLS/SSL tried Implicit and Explicit encryption. Any help with settings to connect to this type of site.
Re: Can't connect to b10ftps.tgms.gxs.com:6366
Can you connect with any other FTP client?
Talking to Opentext GXS support and getting their SSL certificate to use with this FTPS TLS/SSL. Turning on logging, without SSL certificate just gets connection failed, time out.
mdrex01
OH
Here is Winscp log.
Couldn't get good cerificate for the site to use in Winscp they sent .pem but it says not valid certificate when picked in Winscp FTP TLS/SSL. Here is log file:
2016-09-09 11:01:11.453 WinSCP Version 5.9.1 (Build 6885) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Datacenter)
. 2016-09-09 11:01:11.453 Configuration: HKCU\Software\MP\WinSCP 2\
. 2016-09-09 11:01:11.453 Log level: Normal
. 2016-09-09 11:01:11.453 Local account: AWWx\1edisource
. 2016-09-09 11:01:11.453 Working directory: C:\Program Files (x86)\WinSCP
. 2016-09-09 11:01:11.453 Process ID: 3988
. 2016-09-09 11:01:11.453 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2016-09-09 11:01:11.453 Time zone: Current: GMT-6, Standard: GMT-7 (Mountain Standard Time), DST: GMT-6 (Mountain Daylight Time), DST Start: 3/13/2016, DST End: 11/6/2016
. 2016-09-09 11:01:11.453 Login time: Friday, September 09, 2016 11:01:11 AM
. 2016-09-09 11:01:11.453 --------------------------------------------------------------------------
. 2016-09-09 11:01:11.453 Session name: awwx@ax.com@b10ftps.tgms.gxs.com (Site)
. 2016-09-09 11:01:11.453 Host name: b10ftps.tgms.gxs.com (Port: 6336)
. 2016-09-09 11:01:11.453 User name: awwx@ax.com (Password: Yes, Key file: No)
. 2016-09-09 11:01:11.453 Transfer Protocol: FTP
. 2016-09-09 11:01:11.453 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2016-09-09 11:01:11.453 Disable Nagle: No
. 2016-09-09 11:01:11.453 Proxy: None
. 2016-09-09 11:01:11.453 Send buffer: 262144
. 2016-09-09 11:01:11.453 UTF: Auto
. 2016-09-09 11:01:11.453 FTPS: Explicit TLS/SSL [Client certificate: No]
. 2016-09-09 11:01:11.453 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2016-09-09 11:01:11.453 Session reuse: Yes
. 2016-09-09 11:01:11.453 TLS/SSL versions: TLSv1.0-TLSv1.2
. 2016-09-09 11:01:11.453 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2016-09-09 11:01:11.453 Cache directory changes: Yes, Permanent: Yes
. 2016-09-09 11:01:11.453 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2016-09-09 11:01:11.453 Timezone offset: 0h 0m
. 2016-09-09 11:01:11.532 Connecting to b10ftps.tgms.gxs.com:6336 ...
. 2016-09-09 11:01:26.483 Timeout detected. (control connection)
. 2016-09-09 11:01:26.483 Connection failed.
* 2016-09-09 11:01:26.483 (EFatal) Connection failed.
* 2016-09-09 11:01:26.483 Timeout detected. (control connection)
* 2016-09-09 11:01:26.483 Connection failed.
