Timestamp get current date and hour
Rirbeiro
Brazil
Hi Guys,
I have created a script to get the files from remote to local directory by current date, as below:
"get -filemask=*>=%TIMESTAMP#yyyy-mm-dd% /vv447Q/pdfdanfe/* C:\pdfxml_totvs\%TIMESTAMP#yyyymmdd%\"
Is it possible get the file by current date and hour?
Best Regards,
Ricardo Ribeiro
Hi Martin,
The setting on filemask on my script is (-filemask=*>=%TIMESTAMP#yyyy-mm-dd%). This script is working, download the files that has been created on current date.
I would like to download the files by current date and last hour. Is it possible?
Thank you
Rirbeiro
Brazil
Hi Martin,
Is it possible to use the "sinchronize" with "-filemask", just to sinchronize the data files on the current date?
Best Regards,
Sure. The same way:
-filemask="*>=%TIMESTAMP#yyyy-mm-dd hh:00:00%"
Though you may want to use a relative time:
-filemask="*>=1H"
See
https://winscp.net/eng/docs/file_mask#size_time
https://winscp.net/eng/docs/scripting#timestamp
Re: Timestamp get current date and hour
Yes, again, the same way.
