Unable to connect to remote directory IBM mainframe
abarman_
I am using WinNET .NET from nuget.
I am able to open the session with the proper credentials.
It is failing at
//The string is <single-quote>EMA.S44.<single-quote>
var v = session.ListDirectory(@"'EMA.S44.'");
The FTP site is at IBM mainframe.
I was able to connect using WinSCP GUI.
I had to add remote directory at the advanced option as 'EMA.S44.' (Note: exactly with the . and single-quote).
Enabled the log while connecting from GUIwhich worked as following. I am just showing the part.
. 2016-08-30 11:14:48.033 Changing directory to "'EMA.S44.'".
> 2016-08-30 11:14:48.033 CWD 'EMA.S44.'
< 2016-08-30 11:14:48.040 250 "EMA.S44." is the working directory name prefix.
. 2016-08-30 11:14:48.040 Getting current directory name.
> 2016-08-30 11:14:48.040 PWD
< 2016-08-30 11:14:48.044 257 "'EMA.S44.'" is working directory.
. 2016-08-30 11:14:48.236 Retrieving directory listing...
Now, while connecting using C# code, digging to exception I found the following.
"winscp> ls -- \"'EMA.S44.'/\""
"Error listing directory ''EMA.S44.''."
"Could not retrieve directory listing\r"
"CWD cmd failed : EDC5129I NO SUCH FILE OR DIRECTORY."
Note:Here is some details about name directory prefix....
https://www.ibm.com/docs/en/zos/latest?topic=codes-250-directory-is-working-directory-name-prefix
I also used generate URL code, and it is as follows. I did hide server details.
winscp-ftpes://*****@ftp.***.***.***/%27EMA.S44.%27/
Please let me know if you see some thing obvious.
Re: Unable to connect to remote directory IBM mainframe
Duplicate post on Stack Overflow:
