Timeout when downloading large files
Tutul
We are trying to use WinSCP to download large files from Azure FTP server. However the process returns 'Timeout detected (control connection' after the file has been downloaded at the local path.
In C#, due to this TimeoutException we are unable to proceed further using the downloaded file.
Below are more details:
Protocol: FTP with Explicit encryption
WinSCP version: 5.9
Running on Azure Windows server 2012
The same Timeout error occurs from GUI as well. Actually we are using C# to do the process, which also returns same exception.
Below are the session logs:
> 2016-08-23 10:53:17.524 PWD
< 2016-08-23 10:53:17.524 257 "/Experian" is current directory.
> 2016-08-23 10:53:17.525 CWD /Experian/ecommerce-customer-01062016165959.zip
< 2016-08-23 10:53:17.526 550 The filename, directory name, or volume label syntax is incorrect.
> 2016-08-23 10:53:17.526 TYPE I
< 2016-08-23 10:53:17.527 200 Type set to I.
> 2016-08-23 10:53:17.527 SIZE /Experian/ecommerce-customer-01062016165959.zip
< 2016-08-23 10:53:17.529 213 444203008
> 2016-08-23 10:53:17.529 MDTM /Experian/ecommerce-customer-01062016165959.zip
< 2016-08-23 10:53:17.530 213 20160818124932
. 2016-08-23 10:53:17.530 Retrieving file information successful
. 2016-08-23 10:53:17.530 No timezone difference detected using file \Experian/ecommerce-customer-01062016165959.zip (Listing: 2016-08-18T12:49:00.000Z, UTF: 2016-08-18T12:49:00.000Z)
. 2016-08-23 10:53:17.530 ..;D;0;1899-12-30T00:00:00.000Z;0;"" [0];"" [0];---------;0
. 2016-08-23 10:53:17.530 ecommerce-customer-01062016165959.zip;-;444203008;2016-08-18T12:49:00.000Z;1;"" [0];"" [0];---------;0
. 2016-08-23 10:53:17.530 experian-consumerview-20052016005005.zip;-;4980349623;2016-08-18T13:01:00.000Z;1;"" [0];"" [0];---------;0
. 2016-08-23 10:53:17.530 experian-consumerview-29072016001001.zip;-;5486080539;2016-08-18T13:02:00.000Z;1;"" [0];"" [0];---------;0
. 2016-08-23 10:53:17.530 ukmobile-digital-26112015000000.tar.gz;-;2151120896;2016-08-22T15:13:00.000Z;1;"" [0];"" [0];---------;0
< 2016-08-23 10:53:17.530 Script: D--------- 0 0 ..
< 2016-08-23 10:53:17.530 Script: ---------- 0 444203008 Aug 18 12:49 ecommerce-customer-01062016165959.zip
< 2016-08-23 10:53:17.531 Script: ---------- 0 4980349623 Aug 18 13:01 experian-consumerview-20052016005005.zip
< 2016-08-23 10:53:17.531 Script: ---------- 0 5486080539 Aug 18 13:02 experian-consumerview-29072016001001.zip
< 2016-08-23 10:53:17.531 Script: ---------- 0 2151120896 Aug 22 15:13 ukmobile-digital-26112015000000.tar.gz
> 2016-08-23 10:53:30.592 Script: get -nopermissions -preservetime -transfer="binary" -- "\Experian\experian-consumerview-20052016005005.zip" "C:\Users\alocalbox\AppData\Local\Temp\2\tmp2F12.tmp"
. 2016-08-23 10:53:30.592 Listing file "\Experian\experian-consumerview-20052016005005.zip".
. 2016-08-23 10:53:30.592 Retrieving file information...
> 2016-08-23 10:53:30.592 PWD
< 2016-08-23 10:53:30.594 257 "/Experian" is current directory.
> 2016-08-23 10:53:30.594 CWD /\Experian\experian-consumerview-20052016005005.zip
< 2016-08-23 10:53:30.595 550 The filename, directory name, or volume label syntax is incorrect.
> 2016-08-23 10:53:30.595 TYPE I
< 2016-08-23 10:53:30.596 200 Type set to I.
> 2016-08-23 10:53:30.596 SIZE /\Experian\experian-consumerview-20052016005005.zip
< 2016-08-23 10:53:30.597 213 4980349623
> 2016-08-23 10:53:30.597 MDTM /\Experian\experian-consumerview-20052016005005.zip
< 2016-08-23 10:53:30.598 213 20160818130131
. 2016-08-23 10:53:30.598 Retrieving file information successful
. 2016-08-23 10:53:30.598 \Experian\experian-consumerview-20052016005005.zip;-;4980349623;2016-08-18T13:01:31.000Z;3;"" [0];"" [0];---------;0
. 2016-08-23 10:53:30.598 Copying 1 files/directories to local directory "C:\Users\alocalbox\AppData\Local\Temp\2\"
. 2016-08-23 10:53:30.598 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: tmp2F12.tmp
. 2016-08-23 10:53:30.598 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2016-08-23 10:53:30.598 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2016-08-23 10:53:30.598 File: '/\Experian\experian-consumerview-20052016005005.zip' [2016-08-18T13:01:31.000Z] [4980349623]
. 2016-08-23 10:53:30.599 Copying "/\Experian\experian-consumerview-20052016005005.zip" to local directory started.
. 2016-08-23 10:53:30.599 Binary transfer mode selected.
. 2016-08-23 10:53:30.599 Starting download of /\Experian\experian-consumerview-20052016005005.zip
> 2016-08-23 10:53:30.599 CWD /
< 2016-08-23 10:53:30.600 250 CWD command successful.
> 2016-08-23 10:53:30.600 PWD
< 2016-08-23 10:53:30.602 257 "/" is current directory.
> 2016-08-23 10:53:30.602 TYPE A
< 2016-08-23 10:53:30.603 200 Type set to A.
> 2016-08-23 10:53:30.603 PASV
< 2016-08-23 10:53:30.604 227 Entering Passive Mode (52,178,148,210,19,140).
> 2016-08-23 10:53:30.604 LIST -a
< 2016-08-23 10:53:30.609 125 Data connection already open; Transfer starting.
. 2016-08-23 10:53:30.609 Session ID reused
. 2016-08-23 10:53:30.610 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AES(256) Mac=SHA384
. 2016-08-23 10:53:30.610 TLS connection established
> 2016-08-23 10:53:31.020 TYPE I
< 2016-08-23 10:53:31.021 200 Type set to I.
> 2016-08-23 10:53:31.021 PASV
< 2016-08-23 10:53:31.023 227 Entering Passive Mode (52,178,148,210,19,141).
> 2016-08-23 10:53:31.023 RETR \Experian\experian-consumerview-20052016005005.zip
< 2016-08-23 10:53:31.025 150 Opening BINARY mode data connection.
. 2016-08-23 10:53:31.025 Session ID reused
. 2016-08-23 10:53:31.026 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AES(256) Mac=SHA384
. 2016-08-23 10:53:31.026 TLS connection established
Below are the server logs:
#Software: Microsoft Internet Information Services 8.5
#Version: 1.0
#Date: 2016-08-23 11:00:07
#Fields: date time c-ip cs-username s-ip s-port cs-method cs-uri-stem sc-status sc-win32-status sc-substatus x-session x-fullpath
2016-08-23 11:00:07 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:16 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:16 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:16 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:16 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:16 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:00:27 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:37 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:47 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:57 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:57 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:57 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:57 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:57 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:00:57 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:01:07 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:17 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:27 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:37 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:37 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:37 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:37 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:37 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:37 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:01:48 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:01:58 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:08 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:18 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:18 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:18 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:18 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5001 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:18 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5001 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:18 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:02:28 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:34 40.127.176.253 SCVDLINGESTION\ADLAdmin 10.0.0.5 5005 DataChannelClosed - - 0 0 1544d04b-9801-4400-b757-12dc71821f0c -
2016-08-23 11:02:34 40.127.176.253 SCVDLINGESTION\ADLAdmin 10.0.0.5 21 RETR \Experian\experian-consumerview-20052016005005.zip 226 0 0 1544d04b-9801-4400-b757-12dc71821f0c /Experian/experian-consumerview-20052016005005.zip
2016-08-23 11:02:38 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:48 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:53 40.127.176.253 SCVDLINGESTION\ADLAdmin 10.0.0.5 21 ControlChannelClosed - - 121 0 1544d04b-9801-4400-b757-12dc71821f0c -
2016-08-23 11:02:58 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:58 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:58 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:58 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5002 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:58 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5002 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:02:58 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:03:09 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:19 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:29 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5003 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5003 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:03:49 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:03:59 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:09 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:19 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:19 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:19 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:19 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:19 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:19 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:04:29 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:49 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:59 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:59 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:59 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:59 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:04:59 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:05:10 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:05:20 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:05:30 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:05:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:05:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:05:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:05:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:05:39 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:05:50 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:00 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:10 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:20 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:20 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:20 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:20 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5001 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:20 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5001 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:20 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:06:30 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:40 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:06:50 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:00 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:00 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:00 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:00 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5002 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:00 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5002 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:00 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:07:11 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:21 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:31 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:41 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:41 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:41 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:41 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5003 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:41 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5003 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:07:41 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:07:51 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:01 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:11 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:21 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:21 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:21 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:21 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:21 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:21 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:08:32 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:42 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:08:52 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:02 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:02 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:02 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:02 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:02 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:02 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:09:12 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:22 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:32 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:42 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:42 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:42 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:42 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:42 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:09:42 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:09:53 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:13 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:22 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:22 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:22 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5001 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:22 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5001 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:22 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:10:33 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:43 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:10:53 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5002 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5002 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:11:13 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE I 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:23 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:33 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:43 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:43 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:43 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5003 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:43 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5003 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:11:43 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:11:53 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:13 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:23 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:23 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:23 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:23 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:23 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5004 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:23 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:12:33 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:43 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:12:53 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PWD - 257 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5005 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:03 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
2016-08-23 11:13:14 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:24 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:34 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:44 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 REST 0 350 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:44 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 TYPE A 200 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:44 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 PASV - 227 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:44 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelOpened - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:44 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 5000 DataChannelClosed - - 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 -
2016-08-23 11:13:44 40.127.176.253 SCVDLINGESTION\ADLExperian 10.0.0.5 21 LIST -a 226 0 0 9ee43a6f-2da0-4ed4-a214-e097ebe76819 /Experian
Note: FileZilla is able to download the same file successfully.
Regards
Nirav
Re: Timeout when downloading large files
There's no "Timeout detected" in the log. Please post a complete log file.
Post a full FileZilla log too (a real log file, not the message log from GUI).
