Recursive calls not allowed - Deleting a directory
KLH
I have established that directories exist. I go through the rfi.names list to removed them but always get the Recursive calls not allowed.
public RemovalOperationResult RemoveFiles(string path)
          session.Open(Config.FtpSessionOptions);
          return session.RemoveFiles(session.EscapeFileMask(path));
 RemoteDirectoryInfo rdi = ftpsSession.ListDirectory(ftpPath);
 foreach (RemoteFileInfo rfi in rdi.Files)
    if (rfi.IsDirectory)
         RemovalOperationResult ror;
         ror = ftpsSession.RemoveFiles(ftpPath + rfi.Name);
         if (ror.IsSuccess)
         foreach (RemovalEventArgs removal in ror.Removals){
            log.Event("Removal of " + removal.FileName + " succeeded");
     else
         log.Event("Removal failed.");
         return false;
It doesn't seem to matter what the path is.
It does seem to be resolving to the right point. Everything else I am doing besides removal is working happily. I am very confused.
Re: Recursive calls not allowed - Deleting a directory
Your duplicate post on Stack Overflow:
While this post includes more code, it's not clear what is the ftpsSession and whether the ftpsSession.RemoveFiles is calling WinSCP Session.RemoveFiles or your RemoveFiles method.
KLH
Sorry Martin.
The stuff above the seperator is from my ftpsSession class
class FtpsSession
        using (WinSCP.Session session = new WinSCP.Session())
I hope that makes it clearer.
With the problem being related to the WinSCP.Lock, I tried adding a Thread.Sleep(3000) to give it some time to clear itself out before attempting the removal. This might have solved the issue as it appears to be working, but it feels a bit clunky.
