transerOptions.FileMask does not work
bartplessers
I'm trying to sync my windows phone FTP server to localdisk.
I'm using PowerShell (windows 10)
and WinSCP-5.9.1-Automation
The main part of my script:
$session.add_FileTransferred( { FileTransferred($_) } )
# Connect
$transferoptions = New-Object WinSCP.TransferOptions
# $transferOptions.FileMask = "*>2016-O8-01"
$transferoptions.FileMask = ".txt"
# Synchronize files
$synchronizationResult = $session.SynchronizeDirectories([WinSCP.SynchronizationMode]::Local, $FTPLocalFolder, $FTPRemoteFolder, $false, $transferoptions)
# Throw on any error
$synchronizationResult.Check()
At the end, I only want to sync files where dateModified > 2016-08-01. This filemask didn't work, so I tried with FileMask = ".txt", but this didn't work either: all files are synchronized, no matter what the extension is.
What do I wrong?
Kind regards,
Bart
elmariachi
UK
Re: transerOptions.FileMask does not work
I'm sure I'm missing something here, but how are arguments for TransferOptions actually handled? I've been through the documentation and just can't figure it out in my script - if I include any more than five arguments when using SynchronizeDirectories in a powershell script, I get an error stating 'Error: Cannot find an overload for "SynchronizeDirectories" and the argument count: "6".'.
I'm trying to exclude certain file types (executables) from download via SFTP and also set it to auto resume. The section of the script in question is;
try
# Will continuously report progress of synchronization
# Connect
#Transfer options
$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::On
$file_mask = "*.* | .exe"
$transferOptions.FileMask = $file_mask
# Synchronize files
[WinSCP.SynchronizationMode]::Local, "c:\test", "/test/", $False, $SynchronizationCriteria.Size, $transferOptions)
#Compare files based on file size
#$SynchronizationCriteria.Size
Any pointers would be very much appreciated.
elmariachi
UK
Worked it out just after posting;
# Connect
#Transfer options
$file_mask = "| *.exe;*.bat;*."
# Synchronize files
[WinSCP.SynchronizationMode]::Local, "c:\test", "/test/", $False, $False, [WinSCP.SynchronizationCriteria]::Size, $transferOptions)
I didn't realise that my synchronisation criteria syntax was wrong and this seemed to be interfering with the rest of it.
Still can't get logging working though - using this entry;
$session.SessionLogPath = "C:\scripts\logs\script.xml"
...but not sure where to put it in the script. Have tried several options but, although it doesn't throw an error, it also doesn't create a log file.
You cannot use .xml for a session log file. Use for example .log.
