Two things: exit command and ovewriting of the log file
leonardo07746
cuba
good morning, I need some help on these, the first problem is that the Exit command isn't closing the prompt when the script has finished the job, the cause is that it doesn't run again at the scheduled next time, the prompt stood there just open, the script goes like this
option batch abort
# option transfer binary
cd c:\Program Files
cd WinSCP
@echo off
winSCP.com /command ^
   "option batch abort" ^
   "open ftp://ftpmetropolitano:ftpmetro@192.168.xxx.x1/ " ^
   "synchronize local -delete -filemask=|*.rar C:\Sabic\JOURNAL /Journals/TRASVAL/ " ^
   "/log=C:\logsdelScript2.log" /loglevel=1" ^
"exit"
and the second is that the log file has just increased almost a 1 gb file size, how can I do to create a different log file every time the script activates and not overwrite the same log every time.
THANKS
Reply with quote E-mail
Re: Two things: exit command and ovewriting of the log file
You have to move the exit after the other commands (before the /log). And use some log file name patterns to make the name unique.
   "exit" ^
   "/log=C:\logsdelScript2_!Y!M!D!T.log" /loglevel=1
Also your option commands at the beginning of the batch cannot be there. They must be on the WinSCP commandline.
leonardo07746
cuba
YEP, the not overwriting request and patterns work like a charm, thanks, but the exit command is not working properly, the prompt is there everytime.
Does the exit command need to be before the /log.............? that isn't working for me, what am i missing
   "exit" ^
   "/log=C:\LOGS_JOURNALS\logsdelScript_!Y_!M_!D_!T.log" /loglevel=1"
