Upload to all directories within a directory
myultima
EU
Hello!
How can i upload a file into all folders in a "user" directory without manually writing a destination to each folder?
Will this one line work...
put example.txt /home/user/*.*/
instead of..
put example.txt /home/user/folder1/
put example.txt /home/user/folder2/
put example.txt /home/user/folder3/
Because i have a lot of folders and it's going to be hard to manually insert all the destinations.
Thanks!
Re: Upload to all directories within a directory
You can write a (PowerShell) script that enumerates the remote folders and then uploads the files to each.
