get -latest /home/t603/*.txt is not found, get -latest /home/t603/my* is found
t603
Prague
I have a question regarding file mask used in "get -latest" scripting command.
When I define my script as
it does not work, while
it does work.
Can I ask You, if file mask like /home/t603/my*.txt is supported? In GUI Find: File mask it is supported.
Thank You in advance for Your answer, Stepan
Re: get -latest /home/t603/*.txt is not found, get -latest /home/t603/my* is found
