No mapping for the Unicode character
Saul1
Germany
at home I have a SFTP server Bitvise SSH 7.12. Every day I transfer some datas to this server using a batch file.
"c:\Program Files (x86)\WinSCP\Winscp" /console /script=d:\nachEDFB\winscp-mand.txt /log="D:\nachEDFB\winscp-mand.log" /loglevel=0 >text.txt
option batch on
open Server-EDFB-SFTP
synchronize remote -delete d:\mysqldump-NAS\ /mand -filemask="*.rar|*.ntx;*.db"
synchronize remote -delete d:\nachEDFB\ nachEDFB -filemask="*.log|*.ntx;*.db"
Everything worked perfect. Now I updated to Winscp 5.9.6786 and get an error when using the batch file.
No mapping for the Unicode character exists in the target multi-byte code page
Transfer files by using the normal programm everything works fine.
Do someone know what my problem is?
Wolfgang
Reply with quote E-mail
Re: No mapping for the Unicode character
When do you get the error? Before WinSCP starts, when it is starting, or while it is running?
Can you post a screenshot? And your batch file?
What version were you using before?
Saul1
Germany
batch file is:
As you can see in my batch I routed the batch output into a file text.txt
I used 5.7.7 before.
Thanks. So you get the error message in the text.txt? Is there any other output in the text.txt?
Anyway, I have sent you an email with a debug version of WinSCP to the address you have used to register on this forum.
Re: Same problem
ghostshape wrote:
I have the same problem when trying to import known_hosts.
Any advice?
https://winscp.net/tracker/1789
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
