Problem with NET Library 5.9 - Removal parameter $True
Alcasczar
NY
Winscp 5.9.0 .NET Library
Script running under Powershell 3.0
Using Sftp
When the below code runs an error appears that it cannot delete file, the file is not a file though. It's an Actual directory.
try
$logpath = 'C:\logs\Incoming'
if (!(test-path $logpath))
    new-item $logpath -ItemType Directory
# Load WinSCP .NET assembly
Add-Type -Path "C:\Winscp\WinSCPnet.dll"
$VerbosePreference = 'Continue'
$remotePath               = '/Test/Incoming/'
$localPath                = 'C:\Test\Incoming'
$HostKey = "ssh-rsa 2048 50:e8:d0:20:ea:45:98:28:7f:4w:59:89:b9:19:49:99"
[int]$port = 22
    # Setup session options
        HostName = "myserver"
        PortNumber = $port
        UserName = "testuser"
        Password = "Secret"
        SshHostKeyFingerprint = $HostKey
    try
        # Connect
        # Download files
        $transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off
        $transferOptions.FileMask = "*.*|.no_delete,*.tmp,*.part"
        $transferResult = $session.GetFiles($remotePath, $localPath, $True, $transferOptions)
        $transferResult.Check()
             $Filename = $transfer.FileName
             Write-verbose ("Download of {0} succeeded" -f $transfer.FileName)
        # Disconnect, clean up
        $session.Dispose()
        Exit 0
catch [exception]
        Write-Verbose ("Error: {0}" -f $_.Exception.Message)
        Exit 1
catch {
   write-verbose " F A T A L  --  E R R O R"
   add-log $logpath -data $_
The remote side stores a hidden file on the server (Linux) called .no_delete (to protect directories from deletion) and as you can see we don't download that as it's in the exclusion FileMask option. The error that is displayed is
[8/3/2016 2:09 PM] An Error has occurred:  :  Error deleting file '/Test/Incoming/AccessPoint'.
Error code: 4
Error message from server (en-US): Directory is not empty
Common reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
The file that's mentioned in the error is not a file it's an actual Directory.
Any assistance is greatly appreciated.
Re: Problem with NET Library 5.9 - Removal parameter $True
Alcasczar
NY
Attached is a session log.
Thanks!!
  • session-test-log.log (35.13 KB, Private file)
Your SFTP server does not even return the .no_delete in the listing. So WinSCP is not aware of it. If the file is in the AccessPoint subfolder too, that explains why WinSCP fails deleting the subfolder. Had the SFTP server returned the "hidden" file in the listing (what most SFTP servers would do), WinSCP would skip it as instructed by the exclude mask, and won't try to delete the subfolder.
If you want to move all files form the server, keeping the directory structure, use this script (as you know already):
https://winscp.net/eng/docs/library_example_recursive_download_custom_error_handling
Just add the third remove = true argument to the GetFiles.
Alcasczar
NY
Thank you Martin
I was able to discuss the issue with our FTP admins and they setup the account so it can see the .no_delete file and the script runs perfectly without error now.
Cheers.
