Question about Walking the directory tree instead of $Session.Getfiles()
Alcasczar
NY
https://winscp.net/eng/docs/library_example_recursive_download_custom_error_handling
Question, does this process remove the file(s) it downloads on the remote side AND the directories? or should it only be the files? Using Powershell and Winscp 5.9 I noticed the $Session.Getfiles() method seems to attempt to delete the directory when you have the remove parameter set to $true.
Does this Method support using Transfer Options ie In the example I didn't see them being used so I'm curious.
$transferOptions.FileMask = "*.pdf,*.txt|*.tmp,*.exe"
$transferOptions.TransferMode = [Winscp.TransferMode]::Binary
Re: Question about Walking the directory tree instead of $Session.Getfiles()
If you set the remove parameter to true, it will remove whatever you have downloaded. So if you download file, it will remove the file, if you download a directory, it will remove the directory. The example you refer to downloads files only. The directories are created locally by the script/code, they are not "downloaded" by the GetFiles. So even if you add the remove parameter, the directories won't be deleted.
The options (TransferOptions type) is an optional parameter (the 4th, after the remove).
It's not used in the example, so the default transfer options are used.
