Cannot see files uploaded to SFTP site
rbandur
I use C# code to upload files to SFTP.
Program says the files uploaded successfully, but I cannot see them in WinSCP UI.
I use WinSCP version 5.19
Any help would be really appreciated
Re: Cannot see files updated to SFTP
Can you add Session.ListDirectory code after the upload to check/log the remote directory contents after the upload?
Also post GUI log showing the listing with absent uploaded files.
Also, if you upload the file in GUI, can you see it in the remote panel afterwards? Post GUI log file for that too.
rbandur
Thanks for your reply.
My code is trying to upload test1.xml to SFTP, right after that it lists directory in the same session. Listing shows the file test1.xml on SFTP. However I cannot download the file. Also it doesnt shows on UI, also in new session listing also doesn't show the file.
Attaching session log file.
If we copy that file over WinSCP GUI it is showing successfully on UI.
One more issue is with downloading files, none of them are visible for C# code even these which were added to SFTP manually and are displayed on GUI.
Thanks in advance.
Description: WinSCP GUI log when we try to copy test1.xml to sftp via GUI
Description: Session log file
rbandur
Looks we found why we can't see the files upoaded to SFTP
SFTP server is on customer side and if has a service which picks the files and delete them
