Mintty (Cygwin) and version 5.9 error : mintty syntax error in position 'w'
toto21
Marseille France
The latest version 5.9 prevents execution of mintty (Cygwin) via Options> Prerences> Integration> Applications> Client PuTTYerminal path:
C:\cygwin\bin\mintty.exe -t  !@ /bin/bash -ile /home/user/winscpscript/ssh.sh !U !@ !P
Error :
My sh script to manage exotic ports such as ssh 15322 ... and the passing of my password to my clipboard (I know it's not good but so practical)
#/bin/sh
echo "Connection $1@$2"
# copy pwd in clipboard - Once connected thinking (for security) to select anything to crush mintty clipboard
printf  $3 >/dev/clipboard
if [ $1 ==  'user_name_ssh' ]
then
   ssh -p 15322 ${1}@${2}
else
   ssh ${1}@${2}
fi
Thank you to consider this in the next version of winscp
cf other post : https://winscp.net/forum/viewtopic.php?t=16243
Re: Mintty (Cygwin) and version 5.9 error : mintty syntax error in position 'w'
Sorry, I do not understand what is the problem. Can you explain?
toto21
Marseille France
Hello Martin,
Thanks for your response.
Now, with latest version 5.9 when Ctrl P to open ssh session i have this error message :
So i downgrad to 5.7 version and it's ok.
So can you please find out what does WinSCP 5.9 differently that it breaks the script? It's not obvious to me. And I do not have mintty.
toto21
Marseille France
Yes,
Whatever sh script is the interpretation of Client PuTTY/Terminal path
that changed with the verson 5.9 (I have not tested 5.8)
In fact it is as if the 5.9 add a plus option mintty (certainly for putty) - this is what is new with this version of winscp
toto21
Sorry indeed it was not very clear (my english is bad),
In fact it is as if Winscp 5.9 added an option (certainly for putty) to the command line that triggers an error for mintty
Please hold down Shift + Ctrl while clicking the Open in PuTTY command.
It will make WinSCP copy the resolved command to the clipboard.
Please post the command here.
toto21
Marseille France
Hello Martin,
I think I understand what changed.
Before (4.7 version) when checked option Remember session password and it pass it to Putty(SSH) (in Preferences>Integration>Applications) it did not add -pw password to the command line options (for mintty the -p option expects coordinated and not a letter (here w) - which causes an error see https://mintty.github.io/mintty.1.html).
In my case :
becomes
C:\cygwin\bin\mintty.exe -pw mypassword -t  myhost /bin/bash -ile /home/user/winscpscript/ssh.sh myuser myhost mypassword
When the option Remember session password and it pass it to Putty(SSH) is not checked the command becomes :
C:\cygwin\bin\mintty.exe -t  myhost /bin/bash -ile /home/user/winscpscript/ssh.sh myuser myhost
in this case it is script shell the script that bugs (mising third argument : mypassword).
To correct this behavior would have when the pattern !P is present in Putty/Terminal client path (logically Remember session password and it pass it to Putty(SSH) is not checked)
then the password is sent (I hope in 5.9.1)
Martin thank you again for all the energy that you put to reply to this post.
Regards
Claude
toto21
Marseille France
I really understand after reinstall 5.7 for my jog :oops:
becomes on 5.9
-pw is sent before other arguments
becomes on 5.7
C:\cygwin\bin\mintty.exe -t  myhost /bin/bash -ile /home/user/winscpscript/ssh.sh myuser myhost mypassword -pw mypassword
-pw is sent after other arguments
This is the real change between the two versions :(
_________________
Everyone knew that it was impossible. He came a fool who did not know and who did it.
Thanks for all the details.
It should have behaved like this, but it didn't.
https://winscp.net/tracker/1443
