Doesnt append in remote server
dh
I trying to append a small file in the remote server (NonStop Tandem Guardian server), but it doesn't.
It just overwrite it.
I tried many commands, but none of them worked:
put -append -nopermissions -nopreservetime -transfer="ascii" -resumesupport="off" -- "local_file" "remote_file",101
put -append -nopermissions -nopreservetime -transfer="ascii" -- "local_file" "remote_file"
put -append -nopermissions -preservetime -transfer="ascii" -- "local_file" "remote_file"
put -append -transfer="ascii" -- "local_file" "remote_file"
Please help me.
dh
Re: Doesnt append in remote server
Yes, its SFTP.
TransferOptions transferOptions = new TransferOptions
TransferMode = TransferMode.Ascii,
FilePermissions = new FilePermissions { Octal = "0777" },
SpeedLimit = 8192,
OverwriteMode = OverwriteMode.Append,
PreserveTimestamp = false,
ResumeSupport = new TransferResumeSupport { State= TransferResumeSupportState.Off} ,
TransferOperationResult res3 = session.PutFiles(@"local_file", "remote_file", false, transferOptions).Check();
if (res3.IsSuccess)
Console.WriteLine("SUCCESS - TIME: {0}", end3.Subtract(start3));
else
SessionRemoteExceptionCollection erCol = res3.Failures;
foreach (SessionException er in erCol)
Console.WriteLine(er.Message);
What protocol? The put -append works with SFTP protocol only.
See https://winscp.net/eng/docs/scriptcommand_put
dh
I trying it two times and the same results. I am attaching the SessionLog.
  • SessionLog.txt (22.6 KB, Private file)
It looks like a bug in your SFTP server.
In WinSCP GUI, do you get overwrite confirmations, when overwriting an existing file?
dh
Nope. It overwrite just fine in the WinSCP Tool.
How can i append in the WinSCP Tool to check if the SFTP server is the problem?
dh wrote:
No confirmation message.
That's an indication of a server bug that prevents the -append from working.
