Automatically create non-existing, nested folders from upload list.
Registry_Editor
Good afternoon,
I'm trying to write a script to help me upload daily generated content to my server.
We're talking sometimes thousands of individual files each day, arranged like this:
example.com/docs/1/1/2/4/1/2/1/abc.txt
example.com/docs/1/2/2/3/1/3/1/def.txt
example.com/docs/1/1/1/2/3/2/1/4/1/ghi.txt
example.com/docs/1/3/2/1/1/2/3/3/2/3/1/1/jkl.txt
Mostly the folders already exist, however each time the files are generated there is the possibility for additional folders also to be generated. So I need my script to create the folder for each file if it does not already exist.
I made the foolish assumption that
put "C:\files\1\1\2\4\1\2\1\abc.txt" "example.com/docs/1/1/2/4/1/2/1/abc.txt"
would create any directory that didn't already exist and then upload the file to it. I don't see why this is not possible?
To recursively scan each directory to discover if a particular location already exists coupled with the requisite string manipulation to create said folders is starting to sound like an awful lot of work for what should surely be a simple, automatic operation.
Many thanks in advance,
RegEd
Registry_Editor
Re: Automatically create non-existing, nested folders from upload list.
Hi Martin, thanks for the response.
I currently do use the synchronize function but because the amount of files and folders is so large this takes a very long time (1–2 hours every day) and puts unnecessary load on the server. The file generator outputs a list of modified files each time it runs so I am trying to switch over to just uploading the modified files, rather than having to run synchronize for two hours every day.
Kind regards,
RegEd
OK, I see.
Though there's no other solution.
Either create the folders, or use the synchronization.
notvmware
Oklahoma
similar issue
I am trying to upload specific folders and all contents to a destination with no content. I have a list of folders but since this is for a data conversion project not all folders need to be uploaded. Does anyone have any suggestions for this scenario when I have a list of the folders that are needed?
