Check for Updates fails with error 80092013
shaun.merrill@...
Version 5.9 (Build 6786)
Choose Help > Check for Updates from the menu.
Error:
Certificate not trusted.
Error: 80092013, Chain index: 0, Element index: 0
Server certificate verification failed: issuer is not trusted
feR
same error
Recently install same versión on two differents Windows 7 computers, on 64 bits doesn't works but on 32 bits works fine.
Re: Check for Updates fails with error 80092013
Are you all getting the exactly same error message? Including the Error: 80092013?
Do you have some 3rd party firewall or other security solution?
Meserias
Check for updates
steliosh
Athens
Error checking for application updates
Hello.
I have upgraded to the latest version 6.1 build 13674 on Windows 10 22H2 on a corporate network with proxy enabled.
When triggering the option to check for updates I get the following dialogue box
Error:80092012 Chain index: 0, Element Index: 0
Server certificate verification failed: issuer not trusted
Best regards,
Stelios
steliosh
Athens
Hello.
Is there any update on why Windows 10 workstation on a corporate network with proxy enabled can not get WinSCP to update to the latest version?
Best regards,
Stelios
steliosh
Athens
WinSCP applog commandline
Hello Martin,
Have sent you an email the log file that you requested.
Seems like there is a TLS failure.
Tried to copy the certificate into a crt file and then import it into the Trusted Root Certification Authorities but the problem still persists.
Best regards,
Stelios
steliosh
Athens
Update still fails for Win10 pc behind corporate firewall
Hello.
Is the issue with updating the application behind corporate firewall fixed?
I have copied the certificate posted in GitHub and save it in a crt file, tried installing this onto the workstation but it still doesn’t work, same error Check for Updates fails with error 80092013"
Re: Update still fails for Win10 pc behind corporate firewall
This is happening when the corporate firewall replaces certificates of websites. And for some reasons Windows certificate store fails to validate the winscp.net replacement certificate – at least when queries the store the way WinSCP does.
stelios71gr
Athens, Greece
WinSCP CertificateStorage Value in Registry
Hello Martin,
Can you please elaborate on the following post (in bold)?
I cannot seem to update the application on windows 10 which is behind a corporate firewall.
Error: 80092012 (The revocation function was unable to check revocation for the certificate), Chain index: 0, Element index: 0
But you can also use custom path via CertificateStorage value in HKCU\SOFTWARE\Martin Prikryl\WinSCP 2\Configuration\Interface.
