Is it possible to customize the server response string format in the command prompt for FTPS
Dear team,
WinSCP shows the standard server response string in the command prompt like following
< 2016-07-24 13:44:52.240 226 Binary Transfer complete.
Is it possible to change string format by removing everything before the status code?
So, the expected result would be a string with "226 Binary Transfer complete." from the very beginning of the response.
The reason of my question is there is a stand alone application I cannot change and when it parses the FTPS client response from a command prompt mode then it expects the status code to be in the first 3 positions of the response line.
Are there any WinSCP settings to manage this?
Re: Is it possible to customize the server response string format in the command prompt for FTPS
No the session log file is not customizable.
You can of course write a simple script to rewrite the log after WinSCP finishes.
