RSA host key usage for .NET assembly
irrupt
London, Ontario Canada
Is it possible to use the cached RSA key while using the .NET assemblies instead of using the WinSCP.sessionoptions parameters?
I have the RSA key already cached and using the scripting methods work, but when I tried to use the .NET assemblies in Powershell, it doesn't seem to read the WinSCP.ini file.
I can't have the key hard coded in my script or an xml file.
I can't use this option - SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
Is there a WinSCP.sessionoptions parameter that defines the location of the WinSCP.ini so it reads the cached key?
thanks
Re: RSA host key usage for .NET assembly
No. See https://winscp.net/eng/docs/library_from_script#default_config
[quote]I can't have the key hard coded in my script or an xml file.[/qoute]
Why? How's loading a host key fingerprint from a registry better than an XML file? And if you prefer the registry, load it from the registry.
See also https://winscp.net/eng/docs/library_example_known_hosts
