Cannot list files transfered by SFTP
Shrek
Hello there!
I hope you can help me with my issue
I'm running WinSCP 5.7.7 in commande line. I run a script with the /script command, that gets files on a server via SFTP. Once the files are on my computer WinSCP is not able to see them anmore. When I launch the lls command it only lists the ".." <DIR>
Is there a trick to see my files?
I can see the files with the Windows Explorer and CMD/Powershell
I tried to change the rights on the files but with no result.
I tried to create a New File.txt and this file is correctly listed by the lls command.
Other files and folders from the computer are correctly listed.
The only files not listed seem to be the one I got from the SFTP transfert.
Thanks in advance.
Re: Cannot list files transfered by SFTP
Please attach a full session log file showing the problem (using the latest version of WinSCP). The log should show both the download and the lls command.
Shrek
Please find attached the logfile. I've added at the end the CMD Output I get.
You can clearly see that in the logfile the lls command lists the files correctly but in the CMD output I get a incomplete list of files[/code]
  • getdata.log (19.6 KB, Private file)
Shrek
You don't have the CMD output in the logfile? line 252 to 270.
Please find attached again the logfile (I doubled checked before uploading)
  • getdata.log (20.73 KB, Private file)
How do you capture the output?
The log lines with Script: prefix should be what WinSCP prints on the console.
