Preserving timestamps on WebDAV transfers
ShmuelG
NY
Hi, new user here.
Is there any way of having WinSCP automatically update the timestamp of the local file if the "preserve timestamp" option fails to update the server timestamp?
(In FTP Voyager, an option that does this is called "Set local file to match remote when unable to set remote time".)
Re: Preserving timestamps on WebDAV transfers
You mean to update source file timestamp after an upload? WinSCP does not have a feature like this.
ShmuelG
NY
Yes, exactly. But only if preserving the timestamp on the server is not enabled, or is not supported by the server.
So I guess I should post this in the feature request forum.
