Authentication failed with powershell but is OK with gui or command
miniil
Belgium
All is in the title :) Authentication failed with powershell but is ok with gui or command mode.
I generate de script from gui and here it is :
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = "10.10.138.84"
    PortNumber = 21
    UserName = "username"
    Password = "password"
try
    # Connect
    # Your code
finally
    $session.Dispose()
I just replace username and password to not share.
Here is my log from gui
. 2016-07-12 12:05:35.527 --------------------------------------------------------------------------
. 2016-07-12 12:05:35.527 WinSCP Version 5.8.4 RC (Build 6736) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2016-07-12 12:05:35.527 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2016-07-12 12:05:35.527 Log level: Normal, Logging passwords
. 2016-07-12 12:05:35.528 Local account: *****
. 2016-07-12 12:05:35.528 Working directory: C:\Program Files (x86)\WinSCP
. 2016-07-12 12:05:35.528 Process ID: 8860
. 2016-07-12 12:05:35.528 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2016-07-12 12:05:35.528 Time zone: Current: GMT+2, Standard: GMT+1 (Paris, Madrid), DST: GMT+2 (Paris, Madrid (heure d’été)), DST Start: 27/03/2016, DST End: 30/10/2016
. 2016-07-12 12:05:35.528 Login time: mardi 12 juillet 2016 12:05:35
. 2016-07-12 12:05:35.528 --------------------------------------------------------------------------
. 2016-07-12 12:05:35.528 Session name: username@10.10.138.84 (Ad-Hoc site)
. 2016-07-12 12:05:35.528 Host name: 10.10.138.84 (Port: 21)
. 2016-07-12 12:05:35.528 User name: username(Password: password, Key file: No)
. 2016-07-12 12:05:35.528 Transfer Protocol: FTP
. 2016-07-12 12:05:35.528 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2016-07-12 12:05:35.528 Disable Nagle: No
. 2016-07-12 12:05:35.528 Proxy: None
. 2016-07-12 12:05:35.528 Send buffer: 262144
. 2016-07-12 12:05:35.528 UTF: Auto
. 2016-07-12 12:05:35.528 FTPS: None [Client certificate: No]
. 2016-07-12 12:05:35.528 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2016-07-12 12:05:35.528 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2016-07-12 12:05:35.528 Cache directory changes: Yes, Permanent: Yes
. 2016-07-12 12:05:35.528 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2016-07-12 12:05:35.528 Timezone offset: 0h 0m
. 2016-07-12 12:05:36.128 Connecting to 10.10.138.84 ...
. 2016-07-12 12:05:36.128 Connected with 10.10.138.84. Waiting for welcome message...
< 2016-07-12 12:05:36.128 220 -
> 2016-07-12 12:05:36.128 USER username
< 2016-07-12 12:05:36.128 331 User username, password please
> 2016-07-12 12:05:36.128 PASS password
< 2016-07-12 12:05:36.128 230 Password Ok, User logged in
> 2016-07-12 12:05:36.128 SYST
< 2016-07-12 12:05:36.128 215 UNIX Type: L8
> 2016-07-12 12:05:36.128 FEAT
< 2016-07-12 12:05:36.128 211- Additional features supported include:
< 2016-07-12 12:05:36.128  MDTM
< 2016-07-12 12:05:36.128  MFCT
< 2016-07-12 12:05:36.128  MFMT
< 2016-07-12 12:05:36.128  SIZE
< 2016-07-12 12:05:36.128  REST STREAM
< 2016-07-12 12:05:36.128  AUTH TLS
< 2016-07-12 12:05:36.128  AUTH SSL
< 2016-07-12 12:05:36.128  PBSZ
< 2016-07-12 12:05:36.128  EPRT
< 2016-07-12 12:05:36.128  EPSV
< 2016-07-12 12:05:36.128  XCRC
< 2016-07-12 12:05:36.129  XSHA1
< 2016-07-12 12:05:36.129  XSHA256
< 2016-07-12 12:05:36.129  XSHA512
< 2016-07-12 12:05:36.129  XMD5
< 2016-07-12 12:05:36.129  PROT
< 2016-07-12 12:05:36.129  LANG EN*
< 2016-07-12 12:05:36.129  SITE CHMOD
< 2016-07-12 12:05:36.129  SITE PSWD
< 2016-07-12 12:05:36.129  SITE ZONE
< 2016-07-12 12:05:36.129  SITE UTIME
< 2016-07-12 12:05:36.129  MLST Type*;Size*;Modify*;Create*;
< 2016-07-12 12:05:36.129  CLNT
< 2016-07-12 12:05:36.129  CSID
< 2016-07-12 12:05:36.129  RMDA
< 2016-07-12 12:05:36.129  UTF8
< 2016-07-12 12:05:36.129 211 End
> 2016-07-12 12:05:36.129 CLNT WinSCP-release-5.8.4
< 2016-07-12 12:05:36.129 200 Command okay
> 2016-07-12 12:05:36.129 OPTS UTF8 ON
< 2016-07-12 12:05:36.129 220 UTF8 support on
. 2016-07-12 12:05:36.181 Connected
. 2016-07-12 12:05:36.182 --------------------------------------------------------------------------
. 2016-07-12 12:05:36.182 Using FTP protocol.
. 2016-07-12 12:05:36.182 Doing startup conversation with host.
> 2016-07-12 12:05:36.235 PWD
< 2016-07-12 12:05:36.242 257 "/" is the current directory
. 2016-07-12 12:05:36.243 Getting current directory name.
. 2016-07-12 12:05:36.389 Retrieving directory listing...
> 2016-07-12 12:05:36.389 TYPE A
< 2016-07-12 12:05:36.396 200 Type ASCII
> 2016-07-12 12:05:36.396 PASV
< 2016-07-12 12:05:36.404 227 Entering Passive Mode (10,10,138,84,50,29)
> 2016-07-12 12:05:36.404 MLSD
. 2016-07-12 12:05:36.404 Connecting to 10.10.138.84:12829 ...
< 2016-07-12 12:05:36.418 150 Opening data connection
. 2016-07-12 12:05:36.419 size=0;modify=20160304132910;create=20140505104401;perm=cmpledf;type=cdir; .
. 2016-07-12 12:05:36.419 size=0;modify=20160304132910;create=20140505104401;perm=cmpledf;type=pdir; ..
. 2016-07-12 12:05:36.419 size=0;modify=20160502135923;create=20141223084037;perm=cmpledf;type=dir; ADMIN
. 2016-07-12 12:05:36.419 size=0;modify=20151223141805;create=20140506041328;perm=cmpledf;type=dir; TECH
< 2016-07-12 12:05:36.619 226 Transfer complete
. 2016-07-12 12:05:36.620 Directory listing successful
. 2016-07-12 12:05:36.620 ..;D;0;1899-12-30T01:00:00.000Z;0;"" [0];"" [0];---------;0
. 2016-07-12 12:05:36.620 ADMIN;D;0;2016-05-02T13:59:23.000Z;3;"" [0];"" [0];---------;0
. 2016-07-12 12:05:36.620 TECH;D;0;2015-12-23T14:18:05.000Z;3;"" [0];"" [0];---------;0
. 2016-07-12 12:05:36.693 Startup conversation with host finished.
and here is the log for powershell
. 2016-07-12 11:37:36.092 --------------------------------------------------------------------------
. 2016-07-12 11:37:36.093 WinSCP Version 5.7.7 (Build 6257) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2016-07-12 11:37:36.093 Configuration: Command-line options overriding nul
. 2016-07-12 11:37:36.093 Log level: Normal
. 2016-07-12 11:37:36.093 Local account: ****
. 2016-07-12 11:37:36.093 Working directory: C:****
. 2016-07-12 11:37:36.093 Process ID: 2972
. 2016-07-12 11:37:36.093 Command-line: "C:\****\winscp.exe" /xmllog="C:\Windows\TEMP\wscp0424.020EE677.tmp" /xmlgroups /nointeractiveinput /dotnet=577  /ini=nul /log="C:\****\session.log"  /rawconfig Logging\Logging="1" /console /consoleinstance=_1060_2576192_482
. 2016-07-12 11:37:36.093 Time zone: Current: GMT+2, Standard: GMT+1 (Paris, Madrid), DST: GMT+2 (Paris, Madrid (heure d’été)), DST Start: 27/03/2016, DST End: 30/10/2016
. 2016-07-12 11:37:36.093 Login time: mardi 12 juillet 2016 11:37:36
. 2016-07-12 11:37:36.093 --------------------------------------------------------------------------
. 2016-07-12 11:37:36.093 Script: Retrospectively logging previous script records:
> 2016-07-12 11:37:36.093 Script: option batch on
< 2016-07-12 11:37:36.093 Script: batch           on
< 2016-07-12 11:37:36.093 Script: reconnecttime   120
> 2016-07-12 11:37:36.093 Script: option confirm off
< 2016-07-12 11:37:36.094 Script: confirm         off
> 2016-07-12 11:37:36.094 Script: option reconnecttime 120
< 2016-07-12 11:37:36.094 Script: reconnecttime   120
> 2016-07-12 11:37:36.094 Script: open ftp://EBOS5VOO001:***@10.15.136.83:21 -passive=1 -timeout=15
. 2016-07-12 11:37:36.094 --------------------------------------------------------------------------
. 2016-07-12 11:37:36.094 Session name: username@110.10.138.84 (Ad-Hoc site)
. 2016-07-12 11:37:36.094 Host name: 10.10.138.84 (Port: 21)
. 2016-07-12 11:37:36.094 User name: username (Password: Yes, Key file: No)
. 2016-07-12 11:37:36.094 Transfer Protocol: FTP
. 2016-07-12 11:37:36.094 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2016-07-12 11:37:36.094 Disable Nagle: No
. 2016-07-12 11:37:36.094 Proxy: none
. 2016-07-12 11:37:36.094 Send buffer: 262144
. 2016-07-12 11:37:36.094 UTF: 2
. 2016-07-12 11:37:36.094 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2016-07-12 11:37:36.094 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2016-07-12 11:37:36.094 Cache directory changes: Yes, Permanent: Yes
. 2016-07-12 11:37:36.094 Timezone offset: 0h 0m
. 2016-07-12 11:37:36.099 Connecting to 10.10.138.84 ...
. 2016-07-12 11:37:36.107 Connected with 10.10.138.84. Waiting for welcome message...
< 2016-07-12 11:37:36.114 220 -
> 2016-07-12 11:37:36.114 USER username
< 2016-07-12 11:37:36.122 331 User username, password please
> 2016-07-12 11:37:36.122 PASS *****
< 2016-07-12 11:37:39.140 530 Not logged in. Username/password incorrect, user disabled, or user logged in too many times
. 2016-07-12 11:37:39.140 Connection failed.
. 2016-07-12 11:37:39.141 Password prompt (last login attempt failed)
I tried to close all other connection, but it failed.
The only special character in password is $
Thanks for your help.
Re: Authentication failed with powershell but is OK with gui or command
Don't you have some special character in your password or username?
