Questions about synchronize [rename & delete]
IaMa8oY
Sydney
Hi
the SFTP server is on remote VPS, winscp app is at local
I am trying to synchronize multiple files and directories at local c:\local\ and remote /D/remote/, both windows OS.
**Both sides {local or remote} may create/delete/edit/rename files or directories at any time**
Existing Folder Structures:
C:\local\                             /D/remote/
        \File_1.txt                            /File_1.txt
        \File_2.txt                            /File_2.txt
        \Folder_A\                             /Folder_A/
        \Folder_A\File_A1.txt                  /Folder_A/File_A1.txt
        \Folder_A\File_A2.txt                  /Folder_A/File_A2.txt
        \Folder_B\File_B1.txt                  /Folder_B/File_B1.txt
        \Folder_B\File_B2.txt                  /Folder_B/File_B2.txt
Synchronize Code:
option batch abort
open sftp://user:pass@ip:port -hostkey="ecdsa-sha2-nistp384 384 c8:53:70:a4:1b:79:8b:10:0c:5e:9b:45:95:76:33:be"
synchronize both C:\local\ /D/remote/
Create and Edit works without issue.
Create:
When I create files and folders on both sides, it syncs to the other side. So create is all good with the above code.
Edit:
When I edit something in File_B2.txt on both sides, it syncs to the other side. So Edit is all good with the above code.
Delete and rename doesn't work as expected.
Delete:
When I delete files and folders on both sides, it wont delete on the other side.
eg: Steps
.......1) delete folder C:\local\Folder_B
.......2) run the above synchronize Code
it will
.......1) download Folder_B from remote to local
Code: synchronize -delete remote C:\local\ /D/remote/ will work with the above situation.
But it fails if user delete files or folders on remote server first.
Rename:
When I rename files and folders on both sides, it wont rename on the other side.
eg:Steps:
.......1) rename File_1.txt to File_3.txt at Local C:\local\ folder.
it will
.......1) download File_1.txt from remote to local
.......2) upload File_3.txt from local to remote
Not sure how to achieve rename with synchronize, when I test keepuptodate it works.
How to code it to make delete and rename work at any time?
Thanks for your help.
Re: Questions about synchronize [rename & delete]
Deleting is not supported in the "both" mode. There's no way WinSCP can tell, if a file/folder was added on one side or removed from the other.
Removing is similar. How can WinSCP tell that a file was renamed, vs. one file deleted and another file added.
Both problems would require WinSCP to keep the previous state of files somewhere and compare against that.
