Problem with put
p1c0
France
Problem with put
Hi all,
i have difficulties with put...
I try winscp /console /script=script.sh where script.sh is :
option batch on
open root@192.168.1.185:22
option transfer binary
cd /etc/rc.d/init.d
! rm -f iptables
put path_to_file/iptables
but it doesn't work, winscp said it can't find my file path_to_file/iptables.
How can i resolve my problem?
Thanks in advance.
p1c0
p1c0
France
Finally, i have a problem...
When i put a script on a linux box with WinSCP interface, it works perfrctly and i can execute the script locally on the linu box. But when i put the same script with
option batch on
cd /etc/rc.d/init.d
! rm -f iptables
i can't execute the script locally. I have some interprter problems...
I try a "diff file1 file2" and all lines of my script seems to be different but there is no visible changes...
Could you help me please?
p1c0
I have found my problem : my file is in DOS format, so there are \r\n at end of lines.
I have to find how to translate my file in unix format, i've seen dos2unix on the net... i will try this!!!
Use 'option transfer ascii' to enable on-transfer conversion.
