Help with SFTP Download Script
gina.bautista@gmail.com
SLO, CA
I need help. I am trying to build a script that downloads text files via SFTP from a remote site. I am using Powershell 3.0. I've tinkered with Powershell and SFTP add-on, but I'm not getting anywhere with that either. There are always going to be multiple text files and I only want it to grab and pull down those text files. It connects, but it does not download the files where I need them. Script is below.
try
    $logpath = "D:\Report-Copy-Move\Logs\CDCFH-demo_download_results.txt"
   #Source Folders, use absolute path
   #These folders must only have files that are to be downloaded
    $CDCFH_IN = "/username/RDA/IN/CC/MS4/DEM/"
   #Target Folders, use absolute path
    $CDCFH_OUT = "\\transferserver\dignity-billing\agch_fhmc\"
   #Archive Folder Location, use absolute path
    #$CDCFH_Archive = "D:\ininbound\ftp-archive\cdc-archive\"
   #Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
   #Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::sftp
    $sessionOptions.HostName = "mft.dignityhealth.org"
    $sessionOptions.UserName = "username"
    $sessionOptions.Password = "password"
    $sessionOptions.PortNumber = "xxxx"
   #Use the following line with the SSH HostKey Fingerprint by replacing the xx:xx:xx...
    $sessionOptions.SshHostKeyFingerprint = "ssh-rsa 1024 97:83:f1:ec:8c:c4:3b:78:29:d9:c5:10:c8:fe:93:08"
   #ONLY FOR TEST PURPOSES, DO NOT USE AS IS
   #$sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = true
   #$sessionOptions.GiveUpSecurityAndAcceptAnyTlsHostCertificate = true
    $session.SessionLogPath = "D:\Report-Copy-Move\Logs\CDCFH-demo_download-session-log.txt"
    try
       #Connect
       #Force binary mode transfer
       #$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off
        $transferOptions.FilePermissions = $Null # This is default
        $transferOptions.PreserveTimestamp = $False
       #Upload file to the SFTP server directory
       #Note use of absolute path
        $transferResult_CDCFH = $session.GetFiles($CDCFH_IN, $CDCFH_OUT, $False, $transferOptions)
       #Throw on any error to emulate "option batch abort"
        $transferResult_CDCFH.Check()
       #Printing output for CDC and FH
        $cdcfh_counter = 0
        foreach ($transfer in $transferResult_CDCFH.Transfers)
            #Success or error?
            if ($transfer.Error -eq $Null)
                #Print results
                Add-content -Path $logpath -value "Download of {0} succeeded $($transfer.FileName)"
                $cdcfh_counter++
                #Upload succeeded, delete source files
                Remove-Item $transfer.FileName $CDCFH_IN
            else
                #Upload Failed, throw error
                Add-content -Path $logpath -value "Upload failed: {1} $($transfer.FileName) $($transfer.Error.Message)"
        Add-content -Path $logPath -value "$($cdcfh_counter) files successfully downloaded from DIGNITY."
    finally
       #Disconnect, clean up
        $session.Dispose()
        Add-content -Path $logpath -value "Download of Dignity demographics completed"
    exit 0
catch [Exception]
    Add-content -path $logpath -value $_.Exception.Message
    exit 1
Re: Help with SFTP Download Script
Can you describe your problem better than "does not download the files where I need them"?
Can you attach a full session log file showing the problem (using the latest version of WinSCP)?
I've made some changes and I have some success. i will repost script here below. Now what I have is that I need to DELETE the text files on the remote server. I only want to delete the text files. There's a working directory *.working*. I want the script to ignore it and everything in it and only look at the text files. How do I get the script to do that? Script below with log files.
#06/15/2016 Created to download demographic files from Dignity via SFTP
try
   #These folders must only have files that are to be transferred
    $CDCFH_IN = "/username/RDA/IN/CC/MS4/DEM/*.txt"
    $CDCFH_OUT = "\\transferserver\dignity-billing\agch_fhmc\*.txt"
    Add-Type -Path "D:\Report-Copy-Move\SFTP\WinSCPnet.dll"
    $sessionOptions.Password = "pa55w0rd"
    $sessionOptions.PortNumber = "4022"
    try
       #Connect
      Remove-Item $transfer.FileName $CDCFH_IN -inlcude * .txt -exclude *.working*
        $cdcfh_counter = 0
            #Success or error?
                #Print results
                $cdcfh_counter++
            Invoke-Command {Remove-Item -path $CDCFH_IN[0] -Recurse} -ArgumentList
            #Get-ChildItem $CDCFH_IN -Recurse | Remove-Item -Recurse -Force
                #Remove-Item $transfer.FileName $CDCFH_IN -include *.txt
            else
    finally
        $session.Dispose()
    exit 0
catch [Exception]
    exit 1
SESSION LOG FILE:
So list the directory, filter the files you want and delete them.
Start with this example:
https://winscp.net/eng/docs/library_example_listing_files_matching_wildcard
SLO, CA
SFTP Download Log File Blank and code 3 error
Help! I have a WinSCP script with Powershell that is now downloading two text files from a remote host. It downloads to a local share. It deletes the files from the remote host. There are two log files, the session log and the results log. The session log is fine, but I see a code 3 error at the bottom and I don't know how to correct this problem. The results log is blank not giving me the data I expect. I am attaching the script here below. I will attach the two log files also. What am I doing wrong? What am I missing?
try
$logpath = "D:\Report-Copy-Move\Logs\DIGNITY-demo_download_results.txt"
$Demos_French_Arroyo_IN ="/RDA_jkrupa/RDA/IN/CC/MS4/DEM/*.txt"
$Demos_French_Arroyo_OUT = "\\transferserver\DIGNITY-Billing\agch_fhmc\"
$sessionOptions.UserName = "RDA_jkrupa"
$sessionOptions.Password = "xxxxxxxxx"
#If unknown, obtain from log file
$session.SessionLogPath = "D:\Report-Copy-Move\Logs\DIGNITY-demo_download-session-log.txt"
try
#Connect
$transferOptions.FileMask = "/RDA_jkrupa/RDA/IN/CC/MS4/DEM/*.txt"
$session.GetFiles("/RDA_jkrupa/RDA/IN/CC/MS4/DEM/*.txt", "\\transferserver\DIGNITY-BILLING\agch_fhmc\*.txt", $True, $transferOptions)
# Download files to the server directory
# Note use of absolute path
$transferResult_Demos_French_Arroyo = $session.PutFiles($Demos_French_Arroyo_IN, $Demos_French_Arroyo_OUT, $True, $transferOptions)
# Throw on any error to emulate "option batch abort"
# $transferResult_Demos_French_Arroyo.Check()
# Printing output for Demos_French_Arroyo
$Demos_French_Arroyo_counter = 0
foreach ($transfer in $transferResult_Demos_French_Arroyo.Transfers)
# Success or error?
# Print results
Add-content -Path $logpath -value ("Download of {0} succeeded, removing from source" -f
$transfer.FileName)
$Demos_French_Arroyo_counter++
# Download succeeded, remove file from source
$removalResult = $session.RemoveFiles($session.EscapeFileMask($transfer.FileName))
if ($removalResult.IsSuccess)
Add-Content -Path $logpath -value ("Removing of file {0} succeeded" -f
$transfer.FileName)
else
Add-Content -Path $logpath -value ("Removing of file {0} failed" -f
$transfer.FileName)
else
Add-Content -Path $logpath -value ("Download of {0} failed: {1}" -f
$transfer.FileName, $transfer.Error.Message)
finally
$session.Dispose()
Add-content -Path $logpath -value "Download of Dignity Demographic Files Completed"
exit 0
catch [Exception]
exit 1
Description: This is the file that is blank with no line item data in it. I expect the "foreach" to write here.
Re: SFTP Download Log File Blank and code 3 error
You are effectively calling:
$session.PutFiles("/RDA_jkrupa/RDA/IN/CC/MS4/DEM/*.txt", "\\transferserver\DIGNITY-Billing\agch_fhmc\")
Didn't you want to call this instead?
$session.PutFiles("\\transferserver\DIGNITY-Billing\agch_fhmc\*.txt", "/RDA_jkrupa/RDA/IN/CC/MS4/DEM/")
