Cannot find the path specified
anurag
INDIA
Hi All,
I am getting error when uploading a file to the path.
PF attached screenshot of the same.
when I've discussed with my client, he said
Our FTP server is not a traditional FTP server as it does not allow you to query for folders or folder structures. It simply allows you to upload data. Please turn off the setting in your FTP tool that queries folders prior to upload.
can anyone let me know how to turn off the setting which he is talking about.
Many thanks in advance!
Regards,
Anurag.[/url]
Reply with quote E-mail
Re: Cannot find the path specified
anurag
INDIA
Hi Admin,
can you please share a sample script of SFTP file transfer?
I am searching for the script that should be present inside the .bat file and do the file transfer.
let me explain you clearly:
the script inside the .bat file should do sftp file transfer.
can you share any sample scripts?
Thanks in advance!
Regards,
Anurag.
