NO FTP overwrite confirmation
HI, I cannot get any FTP overwrite confirmation, wether the option is checked or not in the Environment.
I did not check "don't ask me again", and I'm working with WinSCP.ini
The same folder full of images was copied and copied again, several times.
XP sp2 guest in a VirtualBox (Win8 host) - WinSCP 5.8.3 (build 6701), but also a previous one.
Re: NO FTP overwrite confirmation
P.S.
I have also observed that an upload was interrupted and left with the current timestamp, while the option was to keep its original date and time (it was probably adjusted once the transfer completed).
This means that it will not be updated on the next attempt, if the break point was not known …
Hope this can help.
P.S.
SORRY, I lost this piece:
Despite the internal Preferences setting, now I see that in WinSCP.ini ConfirmOverwriting=0.
I saved ConfirmOverwriting=1 and tried after re-start to copy existing files, but no confirmation was asked.
Do you use a background or a foreground transfer?
Thanks,
No background, all in view real time.
Now I have uploaded hundreds of files: those already existing are not copied again, but no alert or confirmation request appears.
Sorry to be late, I am a bit busy, since I am setting and transfering domains (and fighting hard with win8);
I will do it soon and post the log file
Uploaded some hundreds of files, I've got 4 errors for some connection faults.
I am not sure if they were fixed, or if files were left incomplete; isn't there a way to see which files were concerned? the log?
Let me answer to myself:
observed that an upload was interrupted and left with the current timestamp, while the option was to keep its original date and time …
this could be the way to filter them.
