Simple .NET Set Up - System.TimeoutException
JohnMontet
I'm running a brand-new .NET installation using 5.7.7 and I'm receiving the following timeout error:
System.TimeoutException: Timeout waiting for WinSCP to respond - WinSCP has not responded in time (response log file C:\Windows\TEMP\wscp1230.017D53CE.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself. at WinSCP.Session.CheckForTimeout(String additional) at WinSCP.Session.Open(SessionOptions sessionOptions)
I've ensured that the user has read/write permissions to the C:\Windows\TEMP\ folder.
I'm using code very similar to the VB.NET example (https://winscp.net/eng/docs/library#vbnet). The WinSCP.exe and WinSCPnet.dll files are located in the /Bin folder of the site.
Any suggestions as to what might be going on? Any help is greatly appreciated.
Re: Simple .NET Set Up - System.TimeoutException
In what environment are you running the code? Is it a desktop application, web application, or other?
JohnMontet
Thank you for your response and attention, prikryl. You can all mark this as solved!
I was using Impersonation. I shut this off in the Web.config and made sure that the IIS Application Pool user had access to the site's root directory.
Like a charm, my friends, like a charm.
Cheers!
Thanks for your feedback.
Did you really had to do both? Or what was the primary cause of the problem?
JohnMontet
I actually had to do both. The application user had to have "Write" privileges for log files to be written. (I couldn't figure out how to shut off logging in the current version.)
OK. What did you do first? Did you try to run the code between the two changes? Did an error message change after the first change?
JohnMontet
Yes. The error I first listed above vanished after I turned off Impersonation.
At that point, the application threw a file stream accessibility issue. Ensuring that the application user had write credentials to the log file location fixed that one.
