FTP Move after upload - not working
vik19
India
I am trying to implement the following, using a powershell file:
https://winscp.net/eng/docs/script_local_move_after_successful_upload
My ftp is ssl, port 990. fingerprint (SHA-1)- 83:93:54:05:c8:87:21:33:d0:50:d6:ef:ba:65:9c:d2:5b:ae:28:5e
After inserting my host, username, and password, I ran the powershell script, however, it did not work. What modifications do I need to make to the script in the link?
Any suggestions pls.
Thank you.
Re: FTP Move after upload - not working
