Editor search issue
Namrur
Editor search issue
When using your program editor and searching for a string on the code, in case the string doesn't exist, or in case you have searched the wrong section (above/underneath) the string, the editor window is thrown to background, and you can't enter it again for a few seconds. Something is freezing in that scenario.
Thanks,
Guy
Re: Editor search issue
What version of Windows and WinSCP are you using? I cannot reproduce the problem.
