Connection Timed Out
Crystina
This is my most current log file
2005-07-31 14:31:21.234 --------------------------------------------------------------------------
. 2005-07-31 14:31:21.234 WinSCP Version 3.7.5 (Build 294) (OS 5.1.2600 Service Pack 2)
. 2005-07-31 14:31:21.234 Login time: Sunday, July 31, 2005 2:31:21 PM
. 2005-07-31 14:31:21.234 --------------------------------------------------------------------------
. 2005-07-31 14:31:21.234 Session name: newjac@sftp.newjac.org
. 2005-07-31 14:31:21.234 Host name: sftp.newjac.org (Port: 22)
. 2005-07-31 14:31:21.234 User name: newjac (Password: Yes, Key file: No)
. 2005-07-31 14:31:21.234 Transfer Protocol: SFTP (SCP)
. 2005-07-31 14:31:21.234 SSH protocol version: 2; Compression: No
. 2005-07-31 14:31:21.234 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-07-31 14:31:21.234 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-07-31 14:31:21.234 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-07-31 14:31:21.234 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-07-31 14:31:21.234 SFTP Bugs: -,-,-
. 2005-07-31 14:31:21.234 Proxy: none
. 2005-07-31 14:31:21.234 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-07-31 14:31:21.234 Shell: default, EOL: 0
. 2005-07-31 14:31:21.234 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-07-31 14:31:21.234 Cache directory changes: Yes, Permanent: Yes
. 2005-07-31 14:31:21.234 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-07-31 14:31:21.234 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-07-31 14:31:21.250 Looking up host "sftp.newjac.org"
. 2005-07-31 14:31:21.687 Connecting to 66.15.12.228 port 22
. 2005-07-31 14:31:42.562 Failed to connect to 66.15.12.228: Network error: Connection timed out
. 2005-07-31 14:31:42.562 Attempt to close connection due to fatal exception:
* 2005-07-31 14:31:42.562 Network error: Connection timed out
. 2005-07-31 14:31:42.562 Closing connection.
* 2005-07-31 14:31:42.562 (ESshFatal) Network error: Connection timed out
I have another domain with the same server that does WinSCP just fine. But I have tried for over a week to get this one going to no avail. Can you please help me?
Re: Connection Timed Out
It may be firewall issue. Are you able to connect to the server with any other SSH client? Or even TCP/IP client?
