WinSCP 5.8.3 RC portable loses site bookmarks
Sarge
EU
Hello !
I use portable version of WinSCP 5.8.2 on Windows 10 32bit, everything is OK.
I tried to replace WinSCP.exe to latest portable one - 5.8.3 RC.
It started and works, but it does not read site bookmarks made by 5.8.2
When I returned 5.8.2 exe back - I see again my site bookmarks.
Seems a bug with 5.8.3 RC portable version, please, check.
Regards,
Serge
Re: WinSCP 5.8.3 RC portable loses site bookmarks
Where do you have your sites/configuration stored? Registry or an INI file? If INI file, where is it stored? What is its name? Are just sites lost or whole configuration?
Sarge
EU
Thank you for the feedback.
The answers as follows
– Portable WinSCP completely stored at mounted disk (VeraCrypt) including sites/configurations/logs
– Configuration stored in .INI file (same dir where portable WinSCP)
– Name - WinSCP.ini
– Only previous Site Bookmarks lost. All other config at place.
Making the tests I found the reason !
582 version stores site bookmarks under IP only
[Configuration\Bookmarks\Remote\root@XXX.XXX.XXX.XX]
but
583 version stores site bookmarks under IP AND PORT
[Configuration\Bookmarks\Remote\root@XXX.XXX.XXX.XX:117]
I have edited WinSCP.ini by text editor adding port number - and previous bookmarks are at place !
[Configuration\Bookmarks\Local\root@
[Configuration\Bookmarks\Options\root@
So during an upgrade from 582 to 583 users must change it manually.
kokkez
Italy
Thank you for sharing @Sarge, I was experiencing the same with the installed version. My configuration is saved in WinSCP.ini, stored into the same folder of the app.
Have a nice day.
Luigi
