How to automatically create log directory if it does not exits?
pmverma
I want to import winscp INI file to many of my client PCs.
However, in case if I provide the log directory which is not created in prior, error will occur.
Is there any way to automatically create log directory if it does not exists.
If not possible from configuration, it is better to do in source.
Could you please tell me which source file and in which function it is possible. :idea:
Thanks in advance.
Re: How to automatically create log directory if it does not exits?
No, it's not possible. Why don't you create the directory as a part of the configuration distribution?
