MV command and change file namn
Lars
I need do add a text (string) to existing filename.
Example:
File before: 4827392021.xml
File after name change: finish4827392021.xml
how can i do this with MV command?
Re: MV command and change file namn
For one file: mv 4827392021.xml finish4827392021.xml.
But if you mean how to do this en masse, it's not possible.
But it's easy to script this using for example PowerShell script with WinSCP .NET assembly.
