Copying file from server based on date today
ebensalot
I have a problem regarding copying file from the server, I want to copy a file based on date only the file generated today will be copied from the server this is my code I use for now:
option batch abort
open sftp://username:password@hostname -hostkey="ssh-rsa 2048 C5:86:05:bd:ce:66:ec:18:e2:10:b6:40:2f:81:a0:a6"
synchronize local C:\Users\LocalPC\Documents\copy1fromserver /media/Server/serverdb/copy1tolocal
I hope you can help me.
Thanks,
Melvin.
ebensalot
Re: Copying file from server based on date today
If you want to download today's files only, use:
get -filemask="*>=%TIMESTAMP#yyyy-mm-dd%" /media/Server/serverdb/copy1tolocal/* C:\Users\LocalPC\Documents\copy1fromserver\
See https://winscp.net/eng/docs/script_download_most_recent_file#alternatives
Hi sir, thanks for your help I have another issue can I get the file before the date to today eg:
after 1:00 am all the folder files yesterday will get from the server by folder.
Thanks,
Melvin.
If I understand your question correctly, you just need to replace the comparison. I.e. use < instead of the >=.
Haribandhu
Copy only previous dated timestamp files from client server
Hi martin,
I am using below condition to copy only previous day timestamp files to local server from client but not working.
get -filemask= "*=yesterday%TIMESTAMP#mm/dd/yyyy%"  /outbox/payment/*  E:\Informatica\9.6.1\server\infa_shared\SrcFiles\
One more thing observed = and *=1D commands are not working
Can you please check and revert on the same.
Thanks in Advance.
best Regards,
hari
