WinSCP and WindowsVista
moonspeller
Connection with server is working well but
no folder names are displayed.
Error message "Invalid memory access" when trying
to change folder.
M.
Grzegorz Niemirowski
Re: WinSCP and WindowsVista
No, there is no SFTP server. The problem occurs with every remote SFTP/SCP server.
OK. now I understand.
On the screenshot I have noticed that the filenames are not displayed for local directory too. Right?
I have sent you an e-mail with screenshot two weeks ago. But OK, I'll send second one.
Sorry, I've forgot. Too many bug reports :-)
mazlang
Vista Beta Error
Hi Martin!
Great job you doing with WinSCP!
Unfortunately I get this Error with VistaBeta: "List Index out of Bounce (-1)"
Do you have a workaround or hotfix for that?
thx
maz
Re: Vista Beta Error
Unfortunatelly I do not have Windows Vista to test it myself.
I have just installed Vista 5219 (Aug 30 build) and WinSCP works fine. There are no problem which were observerd in 5112 and described in beginning of this thread.
Thanks for info.
